Firing an action if a value in between two Range Values?
I want to trigger an info message if a value is in between two range values
Ex:
1.If a Value is in between 10 to 30 then i want to print Info msg as “Value is in between 10 to 30”
  1. If a Value is in between 30 to 50 then i want to print Info msg as “Value is in between 30 to 50”
Give me your ideas to achieve this functionality
Thanks in Advance [:)]
whether you want where to write it or how to write it?
how to write: info(strfmt(“Value is in between %1 to %2”,field1,field2));
where to write: You can write it in many places.
one way is overriding the validateWrite method.(presuming that your are going to show this info while the entry in a form)
Normal conditional functions r enough…
Hi Kranthi,
Thanks for your Reply
Please correct below code it is not working for me
Suggest me if any other ideas
public void init()
super();
if(ProdTable.QtySched <= 1 || ProdTable.QtySched <= 25)
Group1.visible(True);
if(ProdTable.QtySched <= 26 || ProdTable.QtySched <= 50)
Group2.visible(True);
else if (ProdTable.QtySched >= 51 && ProdTable.QtySched <= 90)
Group3.visible(True);
else if (ProdTable.QtySched > 90 && ProdTable.QtySched <= 150)
Group4.visible(True);
else if (ProdTable.QtySched > 150 && ProdTable.QtySched <= 280)
Group5.visible(True);
else if (ProdTable.QtySched > 280 && ProdTable.QtySched <= 500)
Group6.visible(True);
else if (ProdTable.QtySched > 500 && ProdTable.QtySched <= 1200)
Group7.visible(True);
else if (ProdTable.QtySched > 1200 && ProdTable.QtySched <= 3200)
Group8.visible(True);
else if (ProdTable.QtySched > 3200 && ProdTable.QtySched <= 10000)
Group9.visible(True);
else
info(“Please Enter Valid AQL Values”);
Hai Bobby
I feel in first two if conditions ua logic has to be changed as
if(ProdTable.QtySched <= 25)
if(| ProdTable.QtySched <= 50)
or
do you mean like
if(ProdTable.QtySched >= 1 || ProdTable.QtySched <= 25)
if(ProdTable.QtySched >= 26 || ProdTable.QtySched <= 50)
and if you need to display info message for each range limits.Include within the if condition.
I don know whether this would suffice your requirement.
Check these 2 conditions - less than or equal 1 or 25.
the else statement is for which if condition.
You can use simple if else statement
EG :
if(ProdTable.QtySched >= 1 && ProdTable.QtySched <= 25)
else if(ProdTable.QtySched <=50)
else if(ProdTable.QtySched <=90)
Hi Bobby,
You can do in this way.
if(ProdTableQty.QtySched >= 1 && ProdTableQty.QtySched<=25)
Group1.Visible(false);
else if(ProdTableQty.QtySched >= 26 && ProdTableQty.QtySched<=50)
else if(ProdTableQty.QtySched >= 51 && ProdTableQty.QtySched<=90)
