anyone knows what symbol is it ?
Table: 554,
Name: Analysis by Dimensions
Functions: ValidateAnalysisViewCode()
If AnalysisView.Find**(’=<>’)**
Table: 554,
There is no table with id. 554.
There is form id. 554 having function ValidateAnalysisViewCode() and code If NOT AnalysisView.Find**(’=<>’).**
oops sorry manish , you are right, its form 554, my mistake… [:S]
Relevant in this is the context, i.e. some previous statement should assign a value to the PK field(s) of the Record variable you are going to perform the FIND(’=<>") statement on. In our case AnalysisView in the ValidateAnalysisViewCode function:
AnalysisView.Code := AnalysisViewCode;
IF NOT AnalysisView.FIND(’=<>’) THEN
The first line is doing the assignment of a value (i.e. the content of AnalysisViewCode) to the PK field (i.e. Code) of the record variable AnalysisView.
AnalysisView.FIND(’=<>’) is now asking the database server to return the content of the AnalysisView record that
In either of these cases, given the fact that the Analysis View table contains records, this FIND statement will always return a record that will be used in the remaining part of the ValidateAnalysisViewCode function. If no record is found (i.e. … NOT FIND … is true) an error will be thrown saying “You have not yet defined an analysis view.”
Hope this makes sense.
hi luc,
"AnalysisView.Code := AnalysisViewCode;
The first line is doing the assignment of a value (i.e. the content of AnalysisViewCode) to the PK field (i.e. Code) of the record variable AnalysisView."
thanks [:)]
You’re welcome.
Nice explanation
Thanx, Manish.
