I want to find out which users have not logged in NAV in the past 60 days. Is there a specific report or SQL script?
Wassim Minkara
Wassim Minkara
Welcome to DUG!!!
Which version of Navision you are using ?
I am using NAV 5.0 SP1
Hi Wassim,
to check which users are logged in to the NAV-database and long long they are inactive you can run the following script:
You can use this script in a SQL-job and kill the sessions that are inactive for more than xxx minutes. Provided to use at your own risk
;WITH cte as
(SELECT
Db_name(dbid) AS DBName
,Isnull((SELECT TOP 1 'YES ’
FROM INFORMATION_SCHEMA.TABLES
WHERE TABLE_CATALOG = Db_name(dbid)
AND TABLE_NAME = ‘$ndo$dbproperty’), ‘’)
+Isnull((SELECT TOP 1 ‘IT IS’
AND TABLE_NAME = ‘Object’), ‘’) AS NavDatabase
,loginame AS LoginName
,program_name
,login_time
,Datediff(mi, last_batch, Getdate()) InactiveMinutes
,spid
FROM
sys.sysprocesses
WHERE
dbid > 0
and open_tran=0)
SELECT
FROM
cte
WHERE
NavDatabase = ‘YES IT IS’
Thank you for the post. I am looking for inactive users–those who have access but have not logged in NAV within some timeframe (30-60 days). I want to find out who is not actively accessing NAV and revoke their access.
Wassim
