Anyone know how we can find bitmap value of resources in ax 2012…
The form Tutorial_resources
how ??? i can implement in my code
\Classes\SysResource\getResourceNodeData
display Bitmap ResourceImage()
return SysResource::getResourceNodeData(SysResource::getResourceNode(resourceStr(ActionAdvance)));
code compile without error
but in below code
in my these method
void insertImage(int _idx,
str _xlRowCol,
Bitmap _value)
range = excelWorkSheet.Range(_xlRowCol);
range.value(_value);
here , range.value(_value); my program return error during run the code
bitmap value is pass by display method , i know its hardcore for one resource image ;
if you any one scenerio how we can pass resources as a parameter then help me…
That’s not a correct way for adding pictures to Excel. Look at How can I export Image to excel??, for example.
