I want Find and Replace function In NAV 2013r2 .
Hi Seemab,
It does not exists as a standard function in NAV 2013 R2.
But check out this blog post from Microsoft. It shows you a way to create a function, which could do it.
Hi Seema,
Go through this link i hope it will be useful for you.
blogs.msdn.microsoft.com/…/
You have to download the text file and import it into NAV. There is one object in the file, a page 50050. So make sure you don’t have this object number in your database. If you do, then you can edit the object no. directly in the file before you import it. But notice that you need a developer license to import the file.
The “AS-IS” message means that whatever you do with this is your own responsibility. Just like if you create a new object yourself. Microsoft takes no responsibility if you end making your data inaccessible. Like if you implemented this in the G/L Entry table! [:o]
Hello Mr. Erik,
i have downloaded file but it is a text file.how can i import the text file in page. and page 50050 has been already used in objects
As I wrote: “So make sure you don’t have this object number in your database. If you do, then you can edit the object no. directly in the file before you import it.”
Hi Seema,
which ID is not exist in your Page object, take that ID. And open downloaded text file , replace 50050 with your new ID then save the file and import it.
Now it will be imported with new ID for (i.e, 80080).
