I am creating income statement business unit wise. So in AX 2012, I have created business unit as dimension and attach the same with sites and warehouses.
Now when I create a transfer order, financial dimension (Business Unit) attached with the site of ‘From Warehouse’ comes automatically. That is perfect.
But when I proceed further to receive the material in ‘to warehouse’ then financial dimension value of the site attached with ‘to warehouse’ should come which is currently not coming and putting by default value.!
When you need the taxation in transfer of inventory then ‘Stock transfer’ is must.
Transfer order option dont have taxation implications.
B.
There is difference between Dimension and Financial Dimension.
Dimension that you are talking about is inventory dimension which are tracking/Storage dimension of an item.
C.
Not exactly sure for Indian Location manuals from MS for AX 2012 but there is not much change in AX 2009 and AX 2012 as far as Indian localisation is concern.
And Also from different sites you can read them.
My basic question is how can I attach the financial dimension while receiving materials at ‘to warehouse’.?!
Can any one help in that or do I go for customization.?!
I agree with that inventory dimensions and Financial dimensions are different . But i am talking about the Financial dimensions , why we need to attach these to sites when we have option to select the Financial dimensions in stock journal ?
As you got the above issue in the transfer order on 19th February 2013.
What solution you get regarding this. So, can you kindly the solution with me.
Currently. in the transfer order(Stock transfer) the financial dimension of “From warehouse” is coming in the “Shipment Voucher” which is correct also.
but when we do “receive” then at that time in the “receive voucher” the financial dimension of “to warehouse” should flow in the “receive voucher” but instead of that the financial dimension of “from warehouse” is flowing.
So,can you kindly suggest the solution as i think the same problem you got earlier.
Customisation was the solution in this case.
We did customisation and in “receive” tab get financial dimension of warehouse which is receiving the material.
