Has anyone installed Financials 2.6b and Advanced Distribution 2.6b on the same workstation? The setup program seems to think the program is already installed. The programs must each have the same version signiture. Thanks for any ideas. Jack
The new windows installer seems to think all of the versions are the same (Financials, Distribution, Mfg.). But just copy the database from the Distribution on your harddrive, and then use the same executables as the Financials and you are set to go. If you want to run 2 local databases you need to copy all of the program files to a new folder, and run the 2nd application from here in order to have an db manager for each open database. Hope this helps you. Soren
The only difference between versions is the database file. You can still insall multiple versions if you want, just install them into different directories… Craig Bradney Project Manager - Technical Navision Solutions & Services Deloitte Growth Solutions Deloitte Touche Tohmatsu P:+61-2-9322-7796 F:+61-2-9322-7502 E:craig_bradney@deloitte.com.au
Thanks to those of you that responded. As I have found out, the help files are also different as well as the database. Jack
By the way with Advanced Distribution you will have a lot of fun.
