Fezih5
#1
Can someone looks at these codes and tell me why my filters ar not working at all.ONLY FILTERS
Cust. Ledger Entry - OnAfterGetRecord()
“Cust. Ledger Entry”.SETRANGE (“Posting Date”,
Customer.GETRANGEMIN(“Date Filter”),
Customer.GETRANGEMAX(“Date Filter”));
“Cust. Ledger Entry”.SETRANGE (“Cust. Ledger Entry”.“Document Type”,“Cust. Ledger Entry”.“Document Type”::“Payment” );
“Total Payment” += “Cust. Ledger Entry”.Amount;
“Cust. Ledger Entry”.RESET;
“Cust. Ledger Entry”.SETRANGE (“Cust. Ledger Entry”.“Document Type”,“Cust. Ledger Entry”.“Document Type”::" " );
“Total Settlement” += “Cust. Ledger Entry”.Amount;
I would think it is because you set the filters in the wrong trigger…
Shouldn’t it be set in the OnPreDataitem-trigger?
Fezih5
#3
Ok. have put it on trigger OnPreDataitem-trigger but still didnt work.
then i had to do it this way. clear the filters from the code and set it on the cust ledger entry table
DataItemLink = Customer No.=FIELD(No.),Posting Date=FIELD(Date Filter)
so the Qs is why is it that this cant work.
Cust. Ledger Entry - OnPreDataItem()
Isitn;t one and the same thing?
pelle
#4
The second version works fine.
A reason that the first version does’nt work could be the “Cust. Ledger Entry”.RESET, which effectly removes all filters.
Maybe there still is a reset?
//Pelle
You will need to use the CALCFIELDS statement
Albert
