I have written a run base method for site and warehouse functionality to achieve two tasks :
To make the warehouse field lookup visible when a checkbox (Visible) is removed from check.
To filter the warehouse lookup based on the selection of site id.
I wrote the following code as :
public void Fld3_1_modified()
FormStringcontrol control = dialog.formRun().controlCallingMethod();
boolean isFieldModified;
isFieldModified = control.modified();
if(isFieldModified)
dlgLocationId.visible(false);
this.dialogUpdate();
//The above code only works for once and makes the field invisible and the checkbox which i enabled remains enabled even if i try to change it.
void Fld3_1_lookup()
SysTableLookup sysTableLookup = SysTableLookup::newParameters(tableNum(InventLocation), control);
Query query = new Query();
sysTableLookup.addLookupField(fieldNum(InventSite, SiteId));
sysTableLookup.addLookupField(fieldNum(InventLocation, InventLocationId));
if(dlgSiteId.value())
query.addDataSource(tableNum(InventLocation)).addRange(fieldNum(InventLocation, InventLocationId)).value(dlgSiteId.value());
//You can add the ranges for filtering
sysTableLookup.parmQuery(query);
sysTableLookup.performFormLookup();
//The above code has no affect on the lookup fields
I am so much confused about this code
Try to implement your changes on dialogSelectCtrl method.
Have you registered the lookup method for override in dialog?
The range should be on Site
query.addDataSource(tableNum(InventLocation)).addRange(fieldNum(InventLocation, InventSiteId)).value(dlgSiteId.value());
My code is not debugging in dialogcontrol() , so i added it in modified method as
if(isFieldModified)
dlgLocationId.visible(true);
dialog.allowUpdateOnSelectCtrl(True);
I know ismodified is not gonna work here as because i can update my runbase form for only once when it is modified. But i need something that will make the field disapper based on the check and uncheck for that what should i do ??
are you calling the dialogSelectCtr() in your dialog method?
yes i am
following is the code which i am using :
public void dialogSelectCtrl()
super();
If(dialogChkbox.Value() == false)
else
I set the default value of the check box to true my main query is :
- I cannot change my checkbox value
- if i do not make it true by default it makes the field which i want to make invisible without clicking on the checkbox i.e( when i click on any other place on the form it makes the field invisble.)
Look at this example,
\Classes\PriceDiscAdmCopy\dialogSelectCtrl
My query has been resolved the updated methods are :
void Fld2_1_lookup()
InventLocation::lookupBySiteIdAllTypes(dlgLocationId.control(),dlgSiteId.value());
For the filtering the warehouse values based on the lookup
boolean ret= true;
If(!dialogChkbox.Value())
ret = false;
dlgLocationId.visible(ret);
super();
For making the dialog box invisible on checking/unchecking the checkbox value
You have not told us about your version. The example i mentioned is from AX 2012 R3
Thanks a lot bro , but mine was 2009 its done i am starting a new thread now for another query related to it.
