I have designed a form similar to form design which is in ‘Ledger\Inquiries\Tax\India posted tax\Service tax\Service tax’. - form name “ServiceTaxInquiry_IN” .
The fields for the column of the form (i.e)The fields in the ’ Available List’ are taken form another table which is created by me.According tto he fields selected and the date range given the records are fetched form the "LedgerTrans table"
In this newly created form , the method ‘createQuery ‘ which used to filter the recs form the LedgerTrans table ,according to the ‘From date’ and ‘To date’(both dates should be specified mandatorily).
public QueryRun createQuery(FromDate _fromDate, ToDate _toDate)
Query queryLoc = new Query();
str Qstr;
queryBuildDataSource qbds;
LedgerTrans LedgerTrans;
if (_fromDate && _toDate)
// queryLoc.addDataSource(tablenum(LedgerTrans)).addRange(fieldnum(LedgerTrans, TransDate)).value(strfmt(’"%1"…"%2"’,_fromDate, _toDate));
queryLoc.addDataSource(tablenum(LedgerTrans)).addRange(fieldnum(LedgerTrans, TransDate)).value(queryRange(_fromDate,_toDate));
else
queryLoc.addDataSource(tablenum(LedgerTrans));
queryRun = new QueryRun(queryLoc);
// Actual Query Executed
info(strfmt(‘Actual Query Executed’));
qbds = queryLoc.addDataSource(tableNum(LedgerTrans));
info(qbds.toString());
return queryRun;
In this method the statement
returns nothing, because when I decoded the query which is executed. the query passed is “ SELECT * FROM LEDGERTRANS”
Please given me clue as where i am making mistake.
Rajee.
