I’m trying to filter data to appear in lookup, so I have used a query and add the range that I need,
the problem is I need another data to appear in the lookup in some cases,
I have used simple SQL statement
while select * from dAPLoanType1 notExists join dAPGradesLoanTypes
where dAPLoanType1.LoanTypeId == dAPGradesLoanTypes.LoanTypeId
The Question is how I can add the Values from dAPLoanType1.LoanTypeId to appear in the lookup besides the value that appear by the Query ?
This is My code :
public void lookup(FormControl _formControl, str filterStr)
// Define Lookup
SysTableLookup sysTableLookup = SysTableLookup::newParameters(tableNum(DAPEmployeeGradesLoanTypes), _formControl);
// Declaration
Query query = new Query();
QueryBuildDataSource queryBuildDataSource;
DAPEmployeeGrade dAPEmployeeGrade;
DAPEmployeeGradesLoanTypes dAPGradesLoanTypes;
DAPLoanType dAPLoanType1;
// The Value of the Employee Grade of selected Worker
DAPEmployeeGrade empGrade = DAPEmplContract::findActiveContractForEmpl(DAPEmplLoans.Worker).EmployeeGrade;
queryBuildDataSource = query.addDataSource(tablenum(DAPEmployeeGradesLoanTypes));
while select forUpdate * from dAPLoanType1 notExists join dAPGradesLoanTypes
// The Field names that will Appear in the Lookup
sysTableLookup.addLookupfield(fieldNum(DAPEmployeeGradesLoanTypes,LoanTypeId));
sysTableLookup.addLookupfield(fieldNum(DAPEmployeeGradesLoanTypes,EmployeeGrade));
// Limit the Appearance of the Data according to the Range
queryBuildDataSource.addRange(fieldNum(DAPEmployeeGradesLoanTypes, EmployeeGrade)).value(queryValue(empGrade));
sysTableLookup.parmQuery(query);
sysTableLookup.performFormLookup();
