I had Table(2 string field, 1 Enumfield) with the help of that I created on form , In form level I added one more field same as table level Enumfield . This enum is no relation with table ok, and In grid I used Table fields
My requirement is
By using form level Enumfield I want filter data in grid with related to same enum values
Means display the records in grid , where form level Enumvalue == in grid level enum
Example : if I select “customer” in form level enum then filter the records in grid . grid enum == “customer”
I wrote the code in form level Enumfield (modified method) like shown in below
QueryBuildRange =
filterdata = cmpOccupancy_ds.query().dataSourceName(‘cmpOccupancy’).addRange(fieldNum(cmpOccupancy,OccupantType)).value(enum2str(OccupantType1.selection()));
QueryBuildRange = Table_ds.query().dataSourceName(“datasource name”).addRange(fieldNum(Table,field)).value(enum2str(enum.selection()));
But not executed can any one help me?
