Hi Everybody
On NAV 2013 I use Responsibility Center. I want filter by Responsibility on Chart Of Account.
Please give me one solution.
Thanks very much.
Hi Everybody
Thanks very much.
Hi Dinhson,
You don’t have responsibility center on GL Entries, so you cannot filter on responsibility center on the COA.
I have before had the same requirement. And what you could do is to create a “responsibility center” dimension. Typically that dimension already exists, if the customer is using dimensions. So you “fix” a dimension to each responsibility center and then you can filter on that dimension in COA.
Thanks you for reply.
on table GL Entries i link filed Responsibility Center with table Dimension Set Entry on relation field Dimension Set ID
and When I filter on Table G/L Account
TableRaletion = “Dimension Value”.Code WHERE (Global Dimension No.=CONST(9))
But still fails. (Filter Limited Total on Page 16 Chart of Accounts)
What do you mean by fails?
it does not filter results respon Code. I similar manner of Dimension (Brand, Cost Center) but not success.
I recently tried for another issue to use syntax WHERE (Global Dimension No.=CONST(x)) - it seems to be working only with x=1|2…
(should add that my NAV programmer’s skills are rather poor, maybe the above is not correct)
Thanks Modris Ivans. I tried unsuccessfully
