jalalm
1
hello all
i want to filter report ( send query to report) by sent parameter to criteria from a form like bottom image :
for example when i send account number 1000 from form to this report , show this in criteria or join in query report
plz help me to do it
Hello,
your screen shot is not visible, pleas attached it once more time.
Cheers
Sevim
5
Hi ,
You can add the code to your reports fetch method.
I should add the formTableName to the comments lines.
public boolean fetch()
boolean ret;
FormTable formTableTmp; // add the formTable
if(element.args().record().TableId == tablenum(<FormTableName>)) // add the form table
formTableTmp= element.args().record(); //add the form table
this.query().dataSourceNo(1).clearRanges();
this.query().dataSourceNo(1).addRange(fieldnum(CustTable,AccountNum)); //add the report table
this.query().dataSourceNo(1).range(1).value(formTableTmp.AccountNum);
ret = super();
return ret;
I have checked the screenshot, select Query-used option on the top and then try to select the criteria. I think that will work
