Filter_Dialog Field
Hi Friends
I hv a Urgent Requirement.Pls help me out.
We have a form in which we have Room and Game as two fields.We are entering some Games for each Room.Let us Assume that for Room1 we haveChess and Carroms and for Room2 we have Computer and TV. Now we have dialog with Same Fields and Given Relation for Lookup in Dialog.Here my Challenge is when we are selecting Room1, only Games Relevant to Room1 Should display in Lookup of Games Field.Pls Guide me in Cracking this.
Thank You
You can either create a form to call from you class (makes it easier to manipulate fields), or you can do this through code.
I’ve googled a bit and found this example for you: http://www.eggheadcafe.com/software/aspnet/30662230/dialog-lookup.aspx
Hope this helps. [:)]
This issue has been discussed on this forum few days back.You can refer the same-
http://dynamicsuser.net/forums/t/41539.aspx?
