Filter Code Vendor
Hi Everybody
If use function IF xxx* not work
IF “Vendor No.” =‘100*’ THEN textCompany:=‘US’;
IF “Vendor No.” = ‘200*’ THEN textCompany:=‘UK’;
IF “Vendor No.” = ‘300*’ THEN textCompany:=‘SJ’ ;
But not work. Please fix code. Thanks very much.
Best Regards
Dinh Son
Dinh,
The vendor no. cannot contain “*” - so it will never be true!
Also you should NEVER harrdcode such values into your code. Such a hardcoded logic will ALWAYS change. So you should use setup tables instead of hardcoding any values!
I guess you’re trying to use it similar to LIKE in SQL and you want to evaluate the 3 first characters of the vendor no?
the instead something like this
VendNo3 := COPYSTR(“Vendor No.”,1,3);
CASE VendNo3 OF
‘100’ : textCompany := ‘US’;
etc.
Thanks Erik**.**
Hi Dinhson,
You’re welcome. Please verify my answer as the solutions, if it helped you. Thanks.
