Hi All, Navision does not support graphical OCX. I did read in another topic that someone was able to put IE on a Navision form. I’m intrested in a “File Viewer” tool to put on a Navision form. Is that possible, available somewhere ? Thanks !
Hi Nav nav, sorry, i don’t know, if something like that exists, but i’m searching for something similar. I’m looking for a real Treeview. Does anybody know something about that? Thanks in advance, Frank
If you need a tre view, then you can do that very easily in standard Navision, a lot less hassles that way.
Hi David and thanks for your reply. I know, how to do this in Standard Navision, but it doesn’t look as good as for example the MS-Explorer. For a looking good solution i need to show the Symbols and some main data, for example Item.description in one Textbox of a tablebox. And that’s impossible, isn’t it? Greeting, FRank
Is this the sort of thing you are looking to do? http://www.go-live.us/dmks22/prod01.htm Its pretty easy to add the lines as well if you need.
quote:
Originally posted by David Singleton
Is this the sort of thing you are looking to do? ftp://www.go-live.us/dmks22/prod01.htm Its pretty easy to add the lines as well if you need.
Should be http in stead of ftp, but site behaves kind of dodgy.
quote:
Originally posted by gco[Should be http in stead of ftp, but site behaves kind of dodgy.
Thanks. It was just something I threw together since I could not upload on the Download section. Thats what the little “men at Work” symbol is for [xx(].
PS: Ten points to the first person that works out how I did the double click on the “+” to expand and contract.
Hello Nav-Nav & Franck : I was looking for something similar a year ago : http://www.navision.net/forum/topic.asp?TOPIC_ID=3963&SearchTerms=treeview I did not managed to find a component which does perform a hierachical File View as sexy as Windows-Explorer : So one of the alternative is to do a tree view form in Navision which gather Files & Folders information using Navision “File” Table. Example of TreeView Form In Navision
o This Form can be downloaded from here : http://www.navisioner.com/html/treeview.htm (Courtesy Of Jose Femenia Canuelo)
Ooops - http://www.navisioner.com/html/treeview.html Error 404 de HTTP 404 No encontrado El servidor Web no puede encontrar el archivo o la secuencia de comandos que ha solicitado. Compruebe la dirección URL para asegurarse de que la ruta de acceso es correcta. Póngase en contacto con el administrador del servidor si el problema persiste.
David : Corrected! The file extension was .HTM not .HTML http://www.navisioner.com/html/treeview.htm
I did not make myself clear. With File Viewer, I mean a component which shows the contents of a file. For example the contents (text) of a word, excel, picture file.
Yeah sorry, I think we were answering Frank’s request instead of yours.
