Hi, has anyone an idea how it’ s possible to let the user search a file through the windows-file-browse-window? On item-card something similar is realised with the picture-import / export but I cannot learn from it. Thanks for any help! Andreas, Cologne
On item card when importing picture you can browse for graphics file to import. If your goal is to make the same feature, take a look at CodeUnit 412 Common Dialog Management.
Andreas, If you are using the file-browse on a request form then check out the following tip/trick … http://www.mbsonline.org/forum/topic.asp?TOPIC_ID=3206 -john
