Then you pressing PgUp or PgDw, and currsor are in values area Field, and this field are editable, is not refreshed. Form: 522.
Try this, Check the code for the form and make sure the “OnNextRecord” section is blank. It seems that even if there is a “.” in there the Pgup and Pgdn don’t work. John Curtain Business Analyst HLB Consulting - Information Systems Level 32, Nauru House 80 Collins St Melb VIC 3000 Ph: +61 3 9258 6745 Fax: +61 3 9258 6722 Mob: 0411 511 951
This BUG is coused by strange trigers calling order. if we have 5 rec in form, trigers are called in following sequence: OnAfterGetRecord 1 OnAfterGetCurrRecord 1 OnAfterGetRecord 2 OnAfterGetRecord 3 OnAfterGetRecord 4 OnAfterGetRecord 5 OnAfterGetRecord 1 OnAfterGetRecord 2 OnAfterGetRecord 3 OnAfterGetRecord 4 OnAfterGetRecord 5 If value is calculated on OnAfterGetRecord the last calculated value will be on 5 rec. So at the end they should call OnAfterGetCurrRecord !!!
