Hai to all,
Actually my requirement is to get the values (Purchase($), Gross Weight) from Purchase order statistics to
Purchase order list form. Can any body help me regarding this, I am using Nav 2009 R2
Thanks in Advance
Hai to all,
Thanks in Advance
Any reason you can’t show the “Amount Including tax / or vat” field from the purchase header?
And just as that field is a flowfield of the purchase lines - you can create another gross weight flowfield on the purch header the same way. then both will can be added to the list form. don;t forget your calcfields.
Did you get an answer to your question? Did it help you? The members and moderators here on DUG use our spare time and help you for free, all we ask in return is that you spent a few seconds to let us know if we helped you solve your problem.
If any of the suggestions helped you solve your question/problem, then please click the “Verify Solution” on the answer that helped you. This way we can see that your problem is now “resolved” and it will be able to guide other members with the same issue.
Otherwise let us know how if there is something else you like to know.
Have a nice day! [:)]
