hi
the field1 is type date
I want to make condition to field1if it is empty I do something other condtion
but when I try it , it show me error
this is the code :
if ( field1=" " ) /// how I verify if the field type date is empty ?
thank you
hi
this is the code :
thank you
Hi Hakim
This will help you.
http://axaptafreak.blogspot.com/2006/04/specifying-empty-date-values.html
Hi hakim
For date testing it is null or not uou should use a funtion named “datenull()”.
eg:in case of query:
select table1 where table1.field1 == datenull()
eg:in case of form:
field1.valuestr() == datenull()
thank you the two solutions are corrects
tank you
