Is it possible to get all the classes listing and the class’s properties in AOT to extract into Excel?
For example:
Refer to below, I would like to extract in Excel. Can or not?
For example:
Hi Aiman,
Try the below Code in your Jobs
// AX 2009
static void Export_Classes_propertied(Args _args)
SysExcelApplication xlsApplication;
SysExcelWorkBooks xlsWorkBookCollection;
SysExcelWorkBook xlsWorkBook;
SysExcelWorkSheets xlsWorkSheetCollection;
SysExcelWorkSheet xlsWorkSheet;
SysExcelRange xlsRange;
int row = 1;
str fileName;
TreeNode classesNode = TreeNode::findNode(@’\Classes’);
TreeNodeIterator iterator = ClassesNode.AOTiterator();
TreeNode classNode = iterator.next();
ClassName className;
UtilElements utilElements;
System.DateTime CreatedSysDate, ModifiedDate;
utcdatetime UtcCreatedDate, UtcModifiedDate;
str StrCreatedDate, strModifiedDate;
//Filename
fileName = “C:\Users\saadullah\Desktop\Class.xlsx”; // Define your Excel Path
//Initialize Excel instance
xlsApplication = SysExcelApplication::construct();
//Open Excel document
//xlsApplication.visible(true);
//Create Excel WorkBook and WorkSheet
xlsWorkBookCollection = xlsApplication.workbooks();
xlsWorkBook = xlsWorkBookCollection.add();
xlsWorkSheetCollection = xlsWorkBook.worksheets();
xlsWorkSheet = xlsWorkSheetCollection.itemFromNum(1);
//Excel columns captions
xlsWorkSheet.cells().item(row,1).value(“ID”);
xlsWorkSheet.cells().item(row,2).value(“Name”);
xlsWorkSheet.cells().item(row,3).value(“Extends”);
xlsWorkSheet.cells().item(row,4).value(“RunOn”);
xlsWorkSheet.cells().item(row,5).value(“CreatedBy”);
xlsWorkSheet.cells().item(row,6).value(“CreatedDateTime”);
xlsWorkSheet.cells().item(row,7).value(“ChangedBy”);
xlsWorkSheet.cells().item(row,8).value(“ChangedDateTime”);
row++;
while (classNode)
className = classNode.treeNodeName();
classNode.AOTgetProperties(true);
select utilElements
where utilElements.RecordType == UtilElementType::Class
&& utilElements.Name == className;
UtcCreatedDate = utilElements.createdDateTime;
CreatedSysDate = Global::utcDateTime2SystemDateTime(UtcCreatedDate);
UtcCreatedDate = Global::CLRSystemDateTime2UtcDateTime(CreatedSysDate);
StrCreatedDate = DateTimeUtil::toStr(UtcCreatedDate);
UtcModifiedDate = utilElements.modifiedDateTime;
ModifiedDate = Global::utcDateTime2SystemDateTime(UtcModifiedDate);
UtcModifiedDate = Global::CLRSystemDateTime2UtcDateTime(ModifiedDate);
strModifiedDate = DateTimeUtil::toStr(UtcCreatedDate);
xlsWorkSheet.cells().item(row,1).value(classNode.applObjectId());
xlsWorkSheet.cells().item(row,2).value(classNode.AOTgetProperty(‘Name’));
xlsWorkSheet.cells().item(row,3).value(classNode.AOTgetProperty(‘Extends’));
xlsWorkSheet.cells().item(row,4).value(classNode.AOTgetProperty(‘RunOn’));
xlsWorkSheet.cells().item(row,5).value(utilElements.createdBy);
xlsWorkSheet.cells().item(row,6).value(StrCreatedDate);
xlsWorkSheet.cells().item(row,7).value(utilElements.modifiedBy);
xlsWorkSheet.cells().item(row,8).value(strModifiedDate);
row++;
//Check whether the document already exists
if(WinApi::fileExists(fileName))
WinApi::deleteFile(fileName);
//Save Excel document
xlsWorkbook.saveAs(fileName);
xlsWorkbook.comObject().save();
//Close Excel
//xlsApplication.quit();
//xlsApplication.finalize();
Thanks SAADULLAH. It’s work. [:D]
