All,
Is there a way to export an entire CUS layer to a file? I have seen where I can do individual models, but not entire layers. Is this possible and if so, what is the command I use?
Shawn T.
All,
Shawn T.
In AX 2012, layers don’t exist as files anymore. If you want everything from a layer, simply export all models from the layer.
You can also Export all the objects in a particular layer into a Project through AOT.
Martin answer is correct.
Raman Kutala
Martin,
Thanks for you reply. I’ll just work with the models individually.
Shawn T.
