The command itself is correct, the problem must be somewhere else. The error message is confusing, but it indicates that something is wrong about the file. Maybe you canât create files there?
No you cannot export .axmodel from the client system. To give the instance name Open services on the server and look for your AOS service . if you have not changed the default service name it should be like this :
Microsoft Dynamics AX Object Server 6.2$01- MicrosoftDynamicsAX
In this case to export the model you need to run the following command
To export models, youâll need the management shell installed and access to the modelstore database, including sufficient permissions.
The -Config parameter expects an AOS instance name - you can see it (among other places) in the Server Configuration Utility (in parenthesis in Application Object Server Instance field). The cmdlet looks for the value to Windows registry (under HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\Dynamics Server\6.0).
Or you can specify the model store database directly by -Database and -Server parameters.
+ CategoryInfo : OperationStopped: (:) [Export-AXModel], Pipeline
StoppedException
+ FullyQualifiedErrorId : Model USRmodel not found.,Microsoft.Dynamics.AX.
Framework.Tools.ModelManagement.PowerShell.ExportAXModelCommand
This error persists. Am i doing something wrong? Is the command syntax correct?
