I wrote a class to export the table data into csv file and it works but when i try to open exported csv file in spreadsheet some fields are fit into single cell.
For example i have exported some data from PurchLine table to csv. When i open it in spreadsheet, the some of the Name field value in PurchLine table causing the issue.
Please check below highlighted data, name value of the particular line not fitting into cell, for other rows it seem good.
Also find below code which i used to export csv file and please help me to over come this issue.
Code Starts here-------->
[SysEntryPointAttribute(false)]
public void processOperation(exportCSV _contract)
#File
Common tableBuffer;
DictField dictField;
DictTable dictTable;
FieldId fieldId;
FileName fileName;
TableName tableName;
date resultDate;
utcDateTime dateTimeResult;
boolean recordsExist;
int i,j,countTable,executedTable;
container line,line2;
boolean recordExist= false;
FileIOPermission permission;
Days numberDays;
MAX_TablesToExportCSV tablesToExportCSV, tablesToExportCSV2;
str nameOfTable,pathToStore;
MAX_CSVExportPath documentPath;
AsciiIo asci;
str replaceUTC;
int check;
countTable = 0;
executedTable = 0;
check = 0;
numberDays = _contract.parmNoofDays();
resultDate = today()-numberDays;
dateTimeResult= DateTimeUtil::newDateTime(resultDate, 0);
select firstOnly documentPath;
if(documentPath)
pathToStore = documentPath.CSVFilePath;
else
throw error (‘Set up file path to store file’);
select firstOnly tablesToExportCSV2;
if(!tablesToExportCSV2)
throw error(‘Add one or more tables in the master’);
while select tablesToExportCSV order by tablesToExportCSV.ListOfTables asc where tablesToExportCSV.Export == NoYes::Yes
nameOfTable = tablesToExportCSV.ListOfTables;
tableName = nameOfTable;
dictTable = new dictTable(tableName2Id(tableName));
fieldId = dictTable.fieldNext(0);
tableBuffer = dictTable.makeRecord();
select crossCompany tableBuffer where (tableBuffer.createdDateTime >= dateTimeResult) || (tableBuffer.modifiedDateTime >= dateTimeResult) ;
fileName = pathToStore + ‘\’ + tableName + ‘.csv’;
permission = new FileIOPermission(fileName, #io_write);
permission.assert();
asci = new AsciiIo(fileName ,#io_write);
asci.outFieldDelimiter(’,’);
for( i =1; i <= dictTable.fieldCnt(); i++)
dictField = new DictField(dictTable.id(), dictTable.fieldCnt2Id(i));
if(dictField.isSql())
line += [ dictField.name(i) ];
asci.write(line);
line = ConNull();
while select crossCompany tableBuffer where (tableBuffer.createdDateTime >= dateTimeResult) || (tableBuffer.modifiedDateTime >= dateTimeResult)
for( j =1; j <= dictTable.fieldCnt(); j++)
dictField = new DictField(dictTable.id(), dictTable.fieldCnt2Id(j));
if(dictField.name(j) == ‘CREATEDDATETIME’ || dictField.name(j) == ‘MODIFIEDDATETIME’ )
replaceUTC = DateTimeUtil::toStr(tableBuffer.(dictField.id()));
if(replaceUTC && replaceUTC != ‘’ )
replaceUTC = strReplace(replaceUTC, ‘T’, ’ ');
replaceUTC = replaceUTC + ‘.270’;
line2 += [ replaceUTC ];
replaceUTC = ‘’;
else if(dictField.baseType() == Types::String)
line2 += [ ‘"’ + (tableBuffer.(dictField.id())) + ‘"’ ];
else
line2 += [ tableBuffer.(dictField.id()) ];
asci.write(line2);
line2 = ConNull();
recordsExist=true;
countTable++;
executedTable++;
CodeAccessPermission::revertAssert();
info(strFmt(‘Exported %1’,fileName));
info(strFmt(’%1 tables exported out of %2’, executedTable, countTable));
