Hi Stan,
Please see screen shot :-
I added the code for “Unit Cost”, and also made another change, I made this report “Processing Only” so you don’t get the blanlk pages.
Go to the Item Table 27, and look for Field 22, just make sure its called “Unit Cost”.
Note I commented out the line that uses the field “NKS Lama” as I don’t have this field in Cronus.
Just take the // out
Try the below and let me know.
/TH
OBJECT Report 50021 Export Item By Location
OBJECT-PROPERTIES
Date=14/02/07;
Time=10:00:51;
Modified=Yes;
Version List=;
PROPERTIES
ProcessingOnly=Yes;
DATAITEMS
{ PROPERTIES
DataItemTable=Table27;
OnPreDataItem=BEGIN
Window.OPEN(
‘Stanley Bilang :’ + Text001 +
‘@1@@@@@@@@@@@@@@@@@@@@@’);
Window.UPDATE(1,0);
TotalRecNo := Item.COUNTAPPROX;
RecNo :=0;
TempExcelBuffer.DELETEALL;
CLEAR(TempExcelBuffer);
EnterCell(1, 1, Text000, TRUE, TRUE, FALSE);
EnterCell(3, 1, t00, TRUE, TRUE, FALSE);
EnterCell(3, 2, t01, TRUE, TRUE, FALSE);
EnterCell(3, 3, t02, TRUE,TRUE,FALSE);
EnterCell(3, 4, t03, TRUE,TRUE,FALSE);
EnterCell(3, 5, t04, TRUE,TRUE,FALSE);
EnterCell(3, 6, t05, TRUE,TRUE,FALSE);
EnterCell(3, 7, t06, TRUE,TRUE,FALSE);
EnterCell(3, 8, t07, TRUE,TRUE,FALSE);
EnterCell(3, 9, t08, TRUE,TRUE,FALSE);
EnterCell(3, 10, t09, TRUE,TRUE,FALSE);
EnterCell(3, 11, t10, TRUE,TRUE,FALSE);
Row := 3;
END;
OnAfterGetRecord=BEGIN
Row := Row + 1;
//EnterCell(Row, 1, “NKS Lama”, FALSE, FALSE, FALSE);
EnterCell(Row, 2, “No.”, FALSE, FALSE, FALSE);
EnterCell(Row, 3, Description, FALSE, FALSE, FALSE);
EnterCell(Row, 4, FORMAT(ROUND(“Unit Cost”,2)), FALSE, FALSE, FALSE);
RecNo := RecNo + 1;
Window.UPDATE(1,ROUND(RecNo / TotalRecNo * 10000,1));
END;
OnPostDataItem=BEGIN
Window.CLOSE;
TempExcelBuffer.CreateBook;
TempExcelBuffer.CreateSheet(Text000,Text000,COMPANYNAME,USERID);
TempExcelBuffer.GiveUserControl;
END;
SECTIONS
{ PROPERTIES
SectionType=Body;
SectionWidth=12000;
SectionHeight=846;
CONTROLS
{ PROPERTIES
DataItemTable=Table32;
DataItemTableView=SORTING(Item No.,Entry Type,Variant Code,Drop Shipment,Location Code,Posting Date)
WHERE(Location Code=CONST(GD));
DataItemVarName=GD;
DataItemLinkReference=Item;
DataItemLink=Item No.=FIELD(No.),
Posting Date=FIELD(Date Filter);
SECTIONS
{ PROPERTIES
SectionType=Body;
SectionWidth=12000;
SectionHeight=846;
CONTROLS
REQUESTFORM
PROPERTIES
Width=9020;
Height=3410;
CONTROLS
CODE
VAR
TempExcelBuffer@1000000004 : TEMPORARY Record 370;
Window@1000000003 : Dialog;
Row@1000000002 : Integer;
TotalRecNo@1000000001 : Integer;
RecNo@1000000000 : Integer;
Text000@1000000009 : TextConst ‘ENU=Daftar Item BY Location’;
Text001@1000000008 : TextConst ‘ENU=Analisa Data…’;
t00@1000000007 : TextConst ‘ENU=NKS Lama’;
t01@1000000006 : TextConst ‘ENU=NKS’;
t02@1000000005 : TextConst ‘ENU=Description’;
t03@1000000010 : TextConst ‘ENU=Harga’;
t04@1000000011 : TextConst ‘ENU=GD’;
t05@1000000012 : TextConst ‘ENU=DO’;
t06@1000000013 : TextConst ‘ENU=SEWA’;
t07@1000000014 : TextConst ‘ENU=EXT’;
t08@1000000015 : TextConst ‘ENU=BPDI’;
t09@1000000016 : TextConst ‘ENU=DO PENDING’;
t10@1000000017 : TextConst ‘ENU=TOTAL’;
PROCEDURE EnterCell@1000000000(RowNo@1000000005 : Integer;ColumnNo@1000000004 : Integer;CellValue@1000000003 : Text[250];Bold@1000000002 : Boolean;Italic@1000000001 : Boolean;UnderLine@1000000000 : Boolean);
BEGIN
TempExcelBuffer.INIT;
TempExcelBuffer.VALIDATE(“Row No.”,RowNo);
TempExcelBuffer.VALIDATE(“Column No.”,ColumnNo);
TempExcelBuffer.“Cell Value as Text” := CellValue;
TempExcelBuffer.Formula := ‘’;
TempExcelBuffer.Bold := Bold;
TempExcelBuffer.Italic := Italic;
TempExcelBuffer.Underline := UnderLine;
TempExcelBuffer.INSERT;
END;
BEGIN
END.
