Export to excel in d365fo using OfficeOpenXml
Hi, i’m using the OfficeOpenXml to export data to an excel sheet.
I copied the code MS is using in CustCollectionsExcelStatement class.
I was adding more columns and testing and at some point my working excel export failed:
“An unexpected error occurred while attempting to create the workbook that contains the selected transactions.”
after debugging i found that when the number of columns is more than 40 the creation of a table range done in the code below messes up the worksheet when it is saved.
protected void setTransactionWorksheetTable(OfficeOpenXml.ExcelWorksheet _worksheet, OfficeOpenXml.ExcelRange _tableRange)
var table = _worksheet.get_Tables().Add(_tableRange, _worksheet.get_Name());
table.set_TableStyle(TableStyles::Light2);
table.set_ShowTotal(false);
Anyone else seen this?
Can you please elaborate where the code fails?
