I am doing export to excel on my form from AX client installed in my machine. I am getting all the fields which are there in form.But when I take Remote of my server and open the form at that time I am seeing the same form with all the fields but when I do export to excel using CTRL + T in the excel file 4 fields are missing.
There are same data in form both the cases.
What could be the issue?
I am using AX 2012 R2.
Hello Karan,
in order to help you can you please give the more details like
are these personalised fields?
are you running on cu7?
Kunal Patel
Hi Kunal,
There are no personalised fields.
I am running on RTM(Kernal :- 6.2.158.0,Application :- 6.2.1000.4051).
Server is having diffent Kernel version it is on CU7(Kernal :- 6.2.1000.4051,Application :- 6.2.1000.4051).
I again want to remind that everything works fine on my machine.Issue is when i export from client.
Hello Karan,
your all clients need to be synch,
for your issue please try the KB release for cu7
gotdax.blogspot.fr/…/dynamics-ax-2012-r2-export-to-excel.html
