Export to Excel-CSV file -> Date format require is MM/YYYY
Dear all,
I need to export G/L Entries posting date to CSV file in this date format MM/YYYY (e.g. 01/2008). Can anyone help?
Thank you very much.
Best regards,
YK Cheong
You can use FORMAT command:
FORMAT(“Posting Date”, 0, ‘<Month,2>/’)
Cheers,
Viktoras
Dear Viktoras,
Thank you for your advice. I tried your method but when I export Jan 2008 data to excel, the system shows as Jan-08 instead of 01/2008.
Best regards,
Cheong
Have you looked to CSV file using Notepad?
I think that in file you have 01/2008, but Excel shows Jan-08.
Viktoras
The “problem” is Excel, not NAV.
But when exporting, take a look at Automation ‘Microsoft Excel 11.0 Object Library’.Range, that has property NumberFormat.
Or look into table 370, function CreateSheet; search for “Numberformat”.
