I need to import many objects from our german solution partner into the dutch version of NAV. Therefore I want to use Beyond compare to compare the text (txt) export to the dutch version. But comparing a 80mb textfile is a far too much work. So I want to compare one object at a time. Is there a way to export each object to a separate text file?
Awesome! That works great, but the reason I wanted to use that utility was because of the nice function where it changes the date of the exported file to match the modified date on the object.
Thanks for the great report though! This will be very handy as well.
