I am exporting the data to text file from AX.
But the issue is when it exports the data the data comes with double quotation “ASSETS”. I want to data to be exported with out the quotes.
Is there any way i can do like this.
Thanks.
Thanks.
Please Elaborate More…and How do you Export data to Text ?
Good Luck
public static client void main(Args _args)
CommaIo file;
container line;
LedgerTable ledgerTable;
#define.filename(‘c:\accounts2.csv’)
#File
file = new CommaIo(#filename, #io_write);
if (!file || file.status() != IO_Status::Ok)
throw error(“File cannot be opened.”);
while select ledgerTable
line = [
ledgerTable.AccountNum,
ledgerTable.AccountName];
file.writeExp(line);
Instead of CommaIO make use of TextIO
public static client void textFileExporting(Args _args)
TextIO file;
container line;
#define.filename(‘c:\accounts.csv’)
#File
file = new TextIO(#filename, #io_write);
file.outFieldDelimiter(’;’);// for semicolon seperator
line = [ledgerTable.AccountNum,ledgerTable.AccountName];
Thanks kranthi it worked !
Thanks. It works for me
Hi Kranthi
I am exporting a csv file in batch process and i am getting the following error
System.NullReferenceException: Object reference not set to an instance of an object.
I am getting the error at below point of code
textIo =
new TextIo(path, #io_write, 0);
commaTextIo.outFieldDelimiter(";");
But when i run manually i dont get any error. The problem is coming only if i run through batch process.
And also i have several files (1000’s) that get generated and in batch the error is coming after some files are already generated. For eg only around 500 are generated but if i run manually there are around 2000
This is my code
permission =
new FileIOPermission(path, #io_write);
permission.assert();
textIo =
textIo .outFieldDelimiter(";");
CodeAccessPermission::revertAssert();
textIo .write();
I have tried so many ways to give the permissions…
Do you have any idea what might be causing the problem ?
Thanks in Advance
