I’m looking for some help with a technical issue based on data export from “Concorde XAL”. Does anyone know of any features, tools or a traditional import process as well as export to CSV that would allow for NAV2013/R2 to import data from “Concorde XAL”?
The access to the legacy application Concord XAL doesn’t work. They use a proprietary database without ODBC-connections or similar tools and features. The main issue is the export process.
I’ve tried searching the networks but I couldn’t find any good leads.
HI, the company I work for use to use Concorde XAL, we created an ODBC connection to Concorde, then used MS access to pull out the tables we needed, once in access you just open the tables and export what you want to csv files, this is how we transferred our data from Concorde XAL to NAV 2013.
@Matthew: forum has Downloads section - you can upload the installation there.
As I recently wrote answering another thread, all installation media can be freely distributed without fear of licensing infringements.
MS unfortunately doesn’t offer any downloads for old (support ended) versions, besides, XAL is pre-MS product, in fact, Axapta & Navision were not joined yet, too, in XAL era.
Hi Matthew. This sounds like a good plan. Might you follow the hint and copy the files into the Download section? This is probably the quickest way. But I’m also open to any other ways of exchange. I would appreciate it if you could send me the files. I would be very grateful because your solution could be crucial for the success of the whole project.
Thanks in advance for your help on this matter, Ingo
Just a warning - if you decide to contact directly, please do so using the Send an Email link available in your profile page here in forum, do NOT expose your email addresses in forum posts, doing so will make them public and available to spammers.
(For that reason any emails written in forum posts directly which still happen to appear from time to time are removed ASAP by forum’s moderators team)
