Hi All
I want to export records from custTable to .csv file and want that my code will run on server side.
How I can achieve this using Classes.
Regards
Vaibhav Agrawal
Hi All
Regards
Vaibhav Agrawal
Im not sure with my answer.Just try this…
CommaIo file= new CommaIo(FilePath+“filename.csv”,“w”);
container buffer;
DictTable dt = new DictTable(tableNum(YOURTABLE));
int fieldcount;
for (fieldcount =1 ;fieldcount <= dt.fieldCnt();fieldcount++)
buffer += [dt.fieldName(dt.fieldCnt2Id(fieldcount))];
file.writeExp(buffer);
while select YOURTABLE
buffer = ConNull();
buffer +=[YOURTABLE.(dt.fieldCnt2Id(fieldcount))];
file.finalize();
.CSV file means we can do in Job but Server side u should do with Morphix report
msdn.microsoft.com/…/cc967382(v=ax.50).aspx
try it
