export a table to a delimited file??
i need an easy way to export a navision database table to a delimited file… can anyone help? thanks, Trint
Create a dataport. Include all the fields from the table by selecting “Dataport Fields” and then using the “Field Menu” icon on the taskbar. Select all fields and then click back onto the Field Designer window. This should select all the fields in the table for you.
Dataport is the best option. If you don’t have access to dataports, and the table is small, then you can run the table, copy all the records, paste in excel and save as a CSV.
