in expense management module ia m able to create Expenses but while iam attaching receipts i have a problem…
i am able to attach receipts but when i click on view receipts i am not able to view the receipts that i have attached.
if any one has idea pls reply… do we need to change any settings.
Hi Satish,
Are you on AX 2009 RTM or SP1? This was a bug on RTM which got fixed in SP1, if you apply the latest SP, this will be resolved.
hi Zubair,
thanks for ur reply… we are using only ax2009 and not sp1. so the problem is with ax 2009 only if we install sp1 then the problem will be rectified…
thanks a lot…
