I’m trying to use the “Find sales order” function in the return orders form, but anytime I try to mark a Sales order from the “Finding sales order” form in AX, i get the following error. Can someone let me know what to be done with the issue?
So you are getting the error the moment you select a particular sales order or by modifying the quantity to return?
What is the quantity to return on related line? if you are modifying it, how you are doing to it?
I don’t modify the quanitity. the process is like i create a return order for a customer, then i select find sales order, i see a list of sales order which having been invoiced, delivered, or open Basically. when i try selecting a sales order, from the find sales form i get this error.
The error is standard and below is the reason for that
If a SO (with positive qty) is returned or credited, the returned/credited qty must not be zero or negative.
And the other way arround; If a SO (with negative qty) is returned/credited the qty must zero or positive.
