In Inventory Setup (Warehouse - Setup - Inventory Setup), i usually uncheck the expected posting setup
now i want to check the expected cost posting…
but while i want to post sales order there’s a message said that i must fill the Inventory Account (Interim)
is it Inventory Account = Inventory Account (Interim) ?
or can anyone could teach me steps to set expected cost posting. so i could post sales order and other activities correctly and fluently?
Well I wouldn’t say “Don’t use it” I would say only use it if you are sure you need it , and know why you need it. [;)]
In some markets, (the UK for example) accruals are a key component of Accounting, and prior to the introduction of Expected Inventory, I would have coded this requirement into about 50% of all UK Navision clients, and whilst I heard the requirement in many other countries, the K was the only one where many clients had it as a “must have”. Though many will just run a “Goods Received Not Invoiced” report, and manually accrue.
With automatic cost posting, I fought that dramatically when it was first planned for Navision, but the reply was always “but its a tick box, just turn it off”, but once its there, its very hard to convince users to turn it off. Anyway, then I started to concentrate in US clients, and there it was almost every client that simply considered Automatic Posting as a “Must Have”, I even spoke with one NC that wanted the tick box removed, and to make the system Always post to G/L.
Now what would really like is an option “Create Dimensions only on posting” option, that would make a huge performance difference.
Expected cost is used to get an “estimate” of cost of items before receiving the invoice.
If you want to control an “estimate” cost in another G/L account then you want to use “Expected cost”
If you want only to know that you have items that you didn’t receive an invoice, probably you should take another path.
