Exchange Rate company specific
In AX 2012 can I have company specific Exchange Rate? instead of shared across the companies. may I be advised on the setup if exist in standard AX…Thanks!!
You can have multiple Exchange rate types (this is assigned in Ledger - specific to company)
technet.microsoft.com/…/hh242857.aspx
Thanks for the response Kranti.
Please can you give hint where to assign in the ledger…thanks
Set default, budget exchange rate type in Ledger. technet.microsoft.com/…/hh416704.aspx
Hi Kranti - I changed below fields and adjusted the exchange rate. The same adjusted exchange rate I could see in another company. Need more advise solution. Regards
Does the both companies using the same exchange rate type (or) you created the new exchange rate type and assigned to another company Ledger?
Let me rephrase my question - Requirement is not to have shared Exchange Rate between the companies.
yes I have tried setting up new type and then changed the company to see if the new exchange is available and it is present under the newly created type.
Exchange rates are shared across the companies, but you can create multi exchange rate types with different exchange rates and use them for different companies.
Where do I set the company specific type?
Exchange rate types are also shared across companies, but what(default) is assigned to Ledger decides the exchange rate in that company.
This has helped Kranthi…thanks!!
Please can you help with my other query on Deliver Remainder Quantity update in PO.
