hi,
i want to do the following filter
Filter on No. <> item1 and item2
hi,
Did you try
Item.SETFILTER(“No.”,’<>%1 & <>%2’,item1,item2);
it works like that , how can i do the following:
REPEAT
IF SalesInvoice not valid THEN
IF RejectedDocNO = ‘’ then
RejectedDocNO := SH.“No.”
ELSE
RejectedDocNO += ‘|’ + SH.“No.”
UNTIL SH.NEXT = 0
SETFILTER(“Document No.”,’<>%1’, RejectedDocNO );
Where did you write this code?
in a codeunit, the filter will be like the following:
SETFILTER(“Document No.”,’<>%1’,item1|item2|item3|item4,…)
Did you try to print the RejectedDocNO using a message before SETFILTER?
RejectedDocNO = item1|item2|item3|item4|…
Did you try with
SETFILTER(“Document No.”,RejectedDocNO );
i want to filter except the rejecteddoc [ <> RejectedDocNO ]
I never used it with <>…
why dont you modify your login
REPEAT
IF SalesInvoicevalid THEN
IF AcceptedDocNO = ‘’ then
AcceptedDocNO := SH.“No.”
ELSE
AcceptedDocNO += ‘|’ + SH.“No.”
UNTIL SH.NEXT = 0
SETFILTER(“Document No.”,AcceptedDocNO );
