Excel Report
Dear Navision Users,
Am doing a excel report. Got all the records in the report. Here am having a option in table that sales type. This is a option field. It has blank,form 8,Form 8B. At the same time am having a field in option tab in the report called form type. Here am having the option as All, Form 8, Form 8B. In the report if ai filter form 8 am getting only the form 8 records. and also same in the form 8b records. Here the problem is when i select form 8 option and select the excel export option in the excel sheet am getting form 8 record values as well as other recods with zero values. Is there any one help me in solving this problem.
Seshadri.
Hi
Have you used Skip or CurrForm.ShowOutput in any report trigger ?
iy yes then remove that functions and use setrange or set filter functions instead of skip and currform.showoutpt
Jerome Marshal.J
