I was trying to use the excel buffer table to export some data onto an already created spreadsheet formatted with fonts, sizes etc. I have found the code in the export account schedules which seems to work well enough, my code is underneath, however the problem I have found with it, is that it wipes out all Borders defined on the spreadsheet!!.
You can add a function to the excel buffer table.
Call It : SetBorderStyle
SetBorderStyle() : Integer
//>>Border
CASE “Border Style” OF
“Border Style”::xlLineStyleNone:
BEGIN
EXIT(-4142);
END;
“Border Style”::xlContinuous:
BEGIN
EXIT(1);
END;
“Border Style”::xlDash:
BEGIN
EXIT(-4115);
END;
“Border Style”::xlDashDot:
BEGIN
EXIT(4);
END;
“Border Style”::xlDashDotDot:
BEGIN
EXIT(5);
END;
“Border Style”::xlDot:
BEGIN
EXIT(-4118);
END;
“Border Style”::xlDouble:
BEGIN
EXIT(-4119);
END;
“Border Style”::xlSlantDashDot:
BEGIN
EXIT(13);
END;
ELSE
EXIT(-4142);
END;
//<<Border
Add a field Called:
50001 - Border Style - type option
Option String :xlLineStyleNone,xlContinuous,xlDash,xlDashDot,xlDashDotDot,xlDot,xlDouble,xlSlantDashDot
In the EnterCell Section of your report - you can set the boarder
EnterCell(RowNo : Integer;ColumnNo : Integer;CellValue : Text[250];Bold : Boolean;Italic : Boolean;UnderLine : Boolean) : Text[250]
TempExcelBuffer.INIT;
TempExcelBuffer.VALIDATE(“Row No.”,RowNo);
TempExcelBuffer.VALIDATE(“Column No.”,ColumnNo);
TempExcelBuffer.“Cell Value as Text” := CellValue;
(Sample of adding a line under row 10) IF Row = 10 THEN TempExcelBuffer.“Border Style” := 0 ELSE TempExcelBuffer.“Border Style” := 1;
basically that is spam. If you want to re-write it as a helpful post, then fine, but spam is not going to happen. I have broken the links.
If you want to be a part of the community, write an introduction post in the intro forum, and tell us about you and your products and how they can help with Navision, but don’t hide links in a thread like that.
if you don’t reply, I will assume this to be just a bot.
