Hello,
I’m using AX 2009. The issue is the following: I want to import new planned production orders from Excel to the ReqPO table but there is a field called “RefID” which is mandatory and is the identification code of the planned order.
I would want to know how I can import the orders without creating these codes by myself. If I left this field empty AX 2009 doesn’t allow me to import the data because it understands that empty fields are the same and therefore there is a problem with coherence.
Thank you all,
Nacho
