Hi
I am new in MS Navision 2016. But I have to do report using ms excel template. I try to put my template in BLOB Table and write data in template using table excelbuffer function entercell.
This works, but all cells in which is recorded data, parameters is different from cells parameters in template?
And also i have from hyperlink table insert picture in my report. I don’t found way how using excelbuffer functions i shoud be able do this?
I look forward to your comments or suggestions tips.
are there formulas in the template or only cell formatting ?
what are the differences, which values do you write into the cells?
what in detail are the problems ?
In template is only cell formatting.
When I write values into cells all formatting : centre alligment, borders, font, wrap , fill color are disable for this cells. In empty cells all formating is active.
In report which I try to do is very important to keep all format in cells whith value, that is my problem.
