Hi!
Is there any way to excute an MSDOS command with parameters (.NET Console Application) form a Dynamis NAV 5.0 form?
ie. “C:\SMSServer\sendSMS 555632050 Excelltia DEMO TEXT FROM SMSSERVER”
Thank you ver much!
Carlos
Hi!
Thank you ver much!
Carlos
Hi Carlos,
Use the SHELL command
Thanks Dave! Will try !
Hi Carlos,
Like Dave suggests you can use the SHELL command.
I’ve had some issues with it though, so i always use Windows Script Host Object Model.
If you define a variable of type Automation:
WshShell - Automation - ‘Windows Script Host Object Model’.WshShell
It has a method called RUN, that takes 3 parameters.
Try to search for WshShell in the forum, and i’m sure you’ll find a lot of threads on this.
