Wonder why I m getting this error message `There can be only left-aligned workflow step .
I set up Approval Workflow and I defined When event- On condition -Then Response.
Ok forgot it about it , I find the problem .
Since nobody else seems to know it here and it just in case someone else get the same issue, please share the solution. We all like to learn something new…
Hi
I think Its Just Indentation Problem Just Make 1st Line As No indent and followed by All Other events and Responses into Indent of level 1…
Thany you
I think You Found Answer but You Haven’t Published …
If you Found Plz Post Answer So that Other May Also Know.
Thank You [:D]
