Whenever I try to run any report the system throws the below given error:
Error Message (09:50:24 am) No connection could be made because the target machine actively refused it xxx.xxx.x.xxx:8202
I had recently restored the databases (Ax, Model and Base Line) from another server and installed the AOS. The present server has only one instance of AOS, yet it is pointing to 8202 service endpoint port, instead of 8201. I have checked the port in server configuration and it is pointing to 8201. Where is the report execution fetching 8202 from lest there exists no other instance of AOS? I have refreshed the configuration services, checked inbound/ outbound ports, nowhere 8202 is mentioned.
Abhinay
