I am getting error “Windows must be called with parameters” in Item group form when i try to open the View details of the Main account field.
Kindly do check on this issue and update the solution for this post.
Thanks and regards,
D Praveen Kumar.
kranthi
2
This shouldn’t happen unless there is some customization. Please tell us about the changes made.
No Customization has happened. I am using here the new installed system.
Please update me any settings i need to do for this error/issue.
Thanks and regards,
D Praveen Kumar.
It seems you have not defined the chart of accounts on Ledger (in General ledger setup)
