Thanks for the answers I would also go with the replace/rename option.
Just to give you some background. My company just got its partner status and we are trying to figure out how it all works.
I use a licence from “Voice” → “License Key Configuration” → “Microsoft Dynamics NAV Perpetual 2013 R2” My first assumption was that I with this licence could do everything. But I cannot alter the objects in case.
In this specific case the customer have an NAV 2009 R2 installation with a lot of special modules installed (from another partner).
Is it correct that other partners can’t change (rename,delete,edit) these objects or have I misunderstood?
You can not alter other partner no series object with your developer license as the access for alteration of those object given to that partner license.
First thing you might need to Change object no series of partner specific modules in accessible no series for your license and then you need to upgradation.
But not sure whether you can change the no series of object .
Last option would be you need to talk to the partner and come out with some solution.
