Error while trying to configure Role Center Profile
Hi All [:)],
While trying to Configure the RTC profile i am getting an error like
Microsoft Dynamics NAV
You do not have the permission to configure the ‘XXX’ profile.
OK
The Command i have given through the command Prompt is
Microsoft.Dynamics.Nav.Client.exe -configure -profile:“XXX”
I wanted to customize the menu suite in RTC(Hide the Sales and purchase from Department Menu) for a particular user.
Is this error because of my license. I have a developer license with me. Please let me know the walk-through
Are you super user?
Hi mohana [:D],
Yes i am a super user. I have uploaded the License in the server. I think it have the RTC module also. Please let me know which one exactly ? 9100?.
I want some clarification from you. I have seen your post http://www.mibuso.com/forum/viewtopic.php?f=32&t=53861&hilit=RTC+menusuite according to that i am trying to configure a user profile.
My aim is to hide the departments which is not suitable for this particular profile from the menu-suite in RTC.
is this the right way to do it?.
Help me please [:’(]
You need to open RTC in configuration mode
Look at thins link
http://msdn.microsoft.com/en-us/library/dd354992
Hi Amol,
I have tried it, but getting an error which i am not able to understand. The error is given above .
Check your Roles & permission on Navision and Sql Server.
I have installed Nav 2009 r2 in the server and i am super user of the Nav. The sql 2005 is installed default along with nav.
Will you able open RTC client with your user id ?
I hope you are using Windows Authentication/Userid.
Yes i am able to login to RTC as well as Classics. Yes window login i am using
Came acrros this post as I did get the same error message. Found the solution here: Configuring a Profile in Role Tailored client .
In short: you need to be the owner of the profile to be allowed to configure it this way.
