Error while running Microsoft Dynamics AX "Setup.exe"
I have strange problem while running the setup.exe file of Microsoft Dynamics AX 2012 RTM. I’m trying to run the setup to install one of the component. all the required components like DB,AOS…etc are already installed and the environment is running perfectly fine.
The problem occurs when I click in setup.exe file. I get the following error message every time when run the .exe file.
Exception:Microsoft.WindowsInstaller.InstallerExceotion
Message:(Some text in Chinees language)
DataBase=“C:Windows\Installer\ce5957.msi”
FullText:MicrosoftWindosInstaller.InstallerException:(Some text in Chinees language)
at.microsoft.windowsInstaller.Database.OpenDatabase(String filePath, DataBaseOPenMode mode)
at.microsoft.windowsInstaller.Database.ctor(String filePath, DataBaseOPenMode mode)
at microsoft.Dynamics.setup.msi.GetValue(String MsiPathAndFile string value)
at microsoft.Dynamics.setup.msiBase.initialize()
at microsoft.Dynamics.setup.msiSetupSupport.get_instance()
at microsoft.Dynamics.setup.Driver.Main(String[] args)
Please note that the msi file (ce5957.msi) what it is complaining about is nor available in C:Windows\Installer folder or in the Dynamics AX setup package folder.
Tried with many options - running the .exe as Administrator, restating the server, placing the setup in different locaiotns and run the .exe but no luck.
The same setup is working fine on different machine, I feel it is something to do with the OS (May be) I’m not sure though, but it is getting difficult to find out the root cause. Can any one have any idea on what could be reason for this? or any pointers on how to solve this problem. Any help is greatly appreciated.
Could you please get more information about the error message? “Some text in Chinese” doesn’t describe the error very well.
After the server reboot, we now see that .exe file is crashing every time and following is error code. Any clue on this?
=== Setup logging started: 4/11/2016 12:46:49 PM ===
Running file: “D:\Program Files\Microsoft Dynamics AX\60\SetupSupport\AxSetup.exe” RelatedFilesDir=“D:\Setup\6.0\AX 6.0 build 947” AutoRun=1 LogDir=“D:\Program Files\Microsoft Dynamics AX\60\Setup Logs\2016-04-11 12-46-33”
AxSetup version number: 6.0.1108.2423
Microsoft Windows NT 6.1.7601 Service Pack 1 (64 bit)
Interactive: True
2016-04-11 12:46:49Z RelatedFilesDir=D:\Setup\6.0\AX 6.0 build 947
2016-04-11 12:46:49Z LogDir=D:\Program Files\Microsoft Dynamics AX\60\Setup Logs\2016-04-11 12-46-33
2016-04-11 12:46:49Z Property RelatedFilesDir set to: ‘D:\Setup\6.0\AX 6.0 build 947’
2016-04-11 12:46:49Z Property LogDir set to: ‘D:\Program Files\Microsoft Dynamics AX\60\Setup Logs\2016-04-11 12-46-33’
2016-04-11 12:46:49Z Common Property Install Path set to ‘D:\Program Files\Microsoft Dynamics AX\60’.
2016-04-11 12:46:49Z Installation Path retrieved from registry. Value: ‘D:\Program Files\Microsoft Dynamics AX\60’
2016-04-11 12:46:49Z Initializing log file: D:\Program Files\Microsoft Dynamics AX\60\Setup Logs\2016-04-11 12-46-33\DynamicsSetupLog.txt
2016-04-11 12:46:49Z === Starting evaluation of existing installation state ===
2016-04-11 12:46:59Z Application Object Server instance 01 has been installed with the name
01-AX_2012_TEST.
2016-04-11 12:46:59Z MSI file: Components64.msi Installed: True
2016-04-11 12:46:59Z MSI file: HelpServer64.msi Installed: False
2016-04-11 12:46:59Z MSI file: ClientOba64.msi Installed: True
=== Setup logging started: 4/11/2016 12:46:33 PM ===
Running file: “C:\Users\XYZ\AppData\Local\Temp\3\SetupPrep\SetupPrep.exe” RelatedFilesDir=“D:\Setup\6.0\AX 6.0 build 947” AutoRun=1
AxSetup version number: 6.0.947.0
Interactive: True
2016-04-11 12:46:33Z RelatedFilesDir=D:\Setup\6.0\AX 6.0 build 947
2016-04-11 12:46:33Z Property RelatedFilesDir set to: ‘D:\Setup\6.0\AX 6.0 build 947’
2016-04-11 12:46:33Z === Starting evaluation of existing installation state ===
2016-04-11 12:46:33Z MSI file: SetupSupport64.msi Installed: True
2016-04-11 12:46:33Z Common Property Install Path set to ‘D:\Program Files\Microsoft Dynamics AX\60’.
2016-04-11 12:46:33Z Initializing log file: D:\Program Files\Microsoft Dynamics AX\60\Setup Logs\2016-04-11 12-46-33\SetupPrepLog.txt
2016-04-11 12:46:33Z AxSetup has already been installed. SetupPrep will now run it.
2016-04-11 12:46:33Z Running file: D:\Program Files\Microsoft Dynamics AX\60\SetupSupport\AxSetup.exe
2016-04-11 12:46:33Z AxSetup has been started. SetupPrep will wait until it finishes.
2016-04-11 12:47:05Z AxSetup has completed. It’s return code was: ‘-532459699’.
2016-04-11 12:47:05Z Additional information can be found in the AxSetup log file ‘DynamicsSetupLog.txt’.
2016-04-11 12:47:05Z === Setup was canceled or failed. For details see the previous messages in the log.
2016-04-11 12:47:05Z === Setup logging ended: 4/11/2016 12:47:05 PM ErrorLevel/ExitCode: ‘3’ ===
Hello, it says “2016-04-11 12:47:05Z Additional information can be found in the AxSetup log file ‘DynamicsSetupLog.txt’”, please find out this TXT file, it should provide you something to trace after.
I copied content of both text (log) files in the above message. The second line “==setup logging started” is the content of the second log file.
Can you tell us which component are you installing? Did you look into event logs?
Hi Martin,
I’m trying to install “Web service on IIS” component, problem occurs well before, I can run the setup.exe, I can see the Welcome screen from, when I click on “Microsoft Dynamics AX components” under “Install” I see the app crash message.
I have provided the log files above, and the same can be seen in the event log as well. can you help me with this problem? we really need the installation to be working.
Rajesh.
I’m sorry, but if you can’t find any more information then the return code (-532459699), I can’t do anything either. Ensure that you met all prerequisites for installing Web services and if you do, you’ll have to turn to Microsoft.
